B
Bent77
Guest
You sir are smarter than IIt’s not the according to Hoyle method, but you can mig stainless and mild steel using whatever wire is designed for the correct grade of work material. I dwell longer on the mild since it welds “harder” than the stainless, which usually wets out quickly and welds super smooth. I’ve done it with C25 gas, and just brush the weld. It’s not perfect and wouldn’t pass a destructive test, but it’s been sufficient for exhaust work prior to getting a TIG machine.
Not smarter, but dumb enough to do the wrong thing the right way.
David
You also confirmed I’m a hillbilly, for I’ve done it before (minus the fancy brush strokes) but wanted to make sure I had permission before proceeding as a hillbilly
