The Purple Camaro
Ah, so you are saying for your class you can't lower the weight anyway? If so that makes more sense.
Though I find it hard to believe that G force weighs only 15 lbs with that thick plate. I feel like I need to wager some cookies or something. ;) Is that legal? ha ha
Even if I stripped the car, I’d only gain a hundred or so. It’s still stock eliminator trim:
Full interior and fender wells. No interest in ruining a nice car to gain a tenth. If I needed it that bad I’d use a 427 short block
If its on amazon it must be true....:rotfl:
Looks like we were both wrong...it's 22 lbs according to them. Not as bad as I thought but I still would of won the cookies for over 15 lbs. ;) But I admit I was off more lbs than you. Although your tubing looks larger than the one in the picture and many G Force are 25 lbs or more.
@folkenheath
why dont you strip your G body down…..
Strip it down? I don't see anyone advocating for that.
It's not a race car, I just do my best do make sure each part isn't overly heavy.
So to me a quite heavy part that could be significantly lighter for reasonable cost and do the same function is a no brainer. Which is why I made my own that weighs ~3 lbs for $10. But that doesn't mean the part needs to be eliminated. Of course, sometimes it does, I don't have any power steering, power brakes, windshield wipers, etc. So in that way it is stripped down. But it does have a heavy 4L80E OD transmission, 5 harnesses(not just 5 pt, 5 harnesses, 2 in front and 3 in the back(the back are 4 pt)), a back seat, a factory style fuel tank, a trunk, and a 4 speaker sound system.
However, if I stripped the interior I surely wouldn't be able to take the family for rides in it or pick the kids up from school, so it would lose a lot of function. So for me, if it doesn't take away a function I want, or cost a lot of money, etc, I make it lighter.
With that said, Bent's car started out way lighter than mine ended up, I'm jealous on that front. Full framed vehicles aren't light.
Anyway, I understand what you are saying Dave, I should shutup and let the man build his own car. ;) :haha:
Is that really heavy or decent or? Whats oem type stuff back in the 60’s?
From 12 to 13. And I like Pepsi more than cookies :D
Since the manufacturer states it weighs 22 lbs, it looks like its made from bent 3/8" steel plate which should never be used on a car taken to the dragstrip, and bathroom spring scales are extremely inaccurate at low weights, I don't believe for one second that thing weighs 13 lbs.
However, with that said I am going to send you some cookies anyway just for putting up with my harassment. But give me some time I am not making a special trip to get them.
And I like Pepsi better too, (much better than Woka Cola) but it doesn't ship as easy as cookies...
You can beat it more if you want I'll still send the cookies. Just don't show us any pictures of that.
