Did you miss the part about me not even having the budget for expensive leaf springs? Lol!
Used bags, square tube for links, bushings!!!!!!!!
Lol I bagged a square dually like that. Pretty awesome. But yah not super cheap
I think Stephen has told me, or I read it here, that by the time he specs out rear springs to still haul a load and not wrap horribly you pretty much end up at the Tuff Country springs they sell. But I could be remembering wrong.
I plan to run air bags in the crew cab for handling the load of a camper trailer.
I feel you on the leaks. The tired, smoking, old 350 I had wouldn't leave puddles but the fresh 454 does from the rear main. Now the trans/tcase adapter has started to leak. I keep looking at the axles and thinking "well at least they aren't leaking!" I'm springing for the deep pan and lube locker gasket for the 4l80e because I don't want it leaking.
Exactly what Stephen told me when I ordered springs for my K5.I think Stephen has told me, or I read it here, that by the time he specs out rear springs to still haul a load and not wrap horribly you pretty much end up at the Tuff Country springs they sell. But I could be remembering wrong.
https://www.summitracing.com/parts/lub-llt-g4l80Lube locker makes a 4l80e gasket? Sweet!
FYI: grade 8 Allen head fine thread bolts make great center pins and can be had at good hardware stores![]()
Steel.Did you get steel shims or aluminum?
I’ll take heavier than I thought for 6900.
David
