7005lbs.
I can’t help but think about 8.1L swaps.
7005lbs.
But....it's running so well!
...turbo. Several of them.Yeah but there’s no replacement for displacement.
With the Toyota the role of Daisy has shifted a bit
I was thinking the same thing.Have you ruled out tires?
Man this vibration is getting old, I swear it’s getting worse. It comes on just over 60mph and gets worse from there. We drove about 7hrs today, I crawled around inside the Suburban while Christy drove and the vibration is worse at the back. I’m hoping it’s driveline related. I’m taking the rear driveline in to get balanced this week and pulling the cover on the rear diff. I hope everything is ok in there, that shits expensive to fix.
When you remove the shaft get some firm degree numbers from the yokes.
I did that before Blazer bash and it didn’t help.swap the tires front to back see if the vibration moves.
