Time for a new update!
We got the new nitrous lines last week and got them installed and pressure tested. I worked on the tune a bit from the info I got from Induction Solutions and we went to the Drift and Drag event at Firebird on Saturday night. The gates opened at 5,PM but we waited until 8PM to at least let the sun go down. There were so few cars drag racing it was like having a private track rental. I ran 3 times and there was only one of the 3 where I didn't drive straight into the burnout box and that was because there was an oil down on the track.
We put jets in for an ~100hp shot using PWM to bring it on over 1/2 second (just to verify how it worked).
First Run:
[email protected]
I was rusty and forgot to turn the rear brakes back on before I pulled up to the starting line so it spun just before the light went green and I had a slow start.
Second Run:
[email protected]
Third run:
[email protected]
It was very consistent so I didn't bother wasting any more Nitrous.
Based on fuel usage (2hp per 1lb/hr) I was only making ~600hp peak with the nitrous. I'm working on getting it to a tuner to get my gasoline and e85 timing curves dialed in, that should get me the 100hp I'm missing.
Because I went from 4.10:1 to 3.73:1 AND from 275/40R17 (25.7") to 28x10R17 I slowed the driveshaft down by about 17%. Pair that with the big cam, it's pretty lazy off the line still, needs more nitrous! It was over a second faster than when I ran with the old BTR nitrous cam N/A though, so we're improving.
I won't take it back to the track until I get it tuned, then I'll probably run it with the same jets once to see the improvement, then start bumping it up until I get close to 11.5 or 135 (NHRA cage rules).
It felt good to go down the track again, even though it was 100+ out.
