We had another good night at the track last night. I still need to pull the plugs after the last run, but we have a tune for a 350hp shot now.
I forgot my laptop, so Amber had to run home while I was going through tech and she was parking the Silverado as I made the first pass so there's no video.
First Run: 250hp jets installed, nitrous now comes on progressively for .5 seconds and goes to 100% for 6.5 more seconds and cuts off after 7 seconds of spray, 12° of timing pulled, 12:1 target AFR while spraying.
60' - 2.434 - Nitrous pressure was too high and the solenoid didn't open right away, the truck surged majorly off the line until the nitrous came on.
330' - 5.845
1/8 - 8
.470@94.18 - New PB trap speed!
1/4 -
12.895@106.60
Second Run: We just checked the data and got back in the lanes, no changes.
RT - .043 - New PB (the only reason I posted this, my RTs are all over the place because I keep changing things)
60' - 1.982 - Aggressively purged the nitrous to prevent the previous issue.
330' - 5.088
1/8 - 7.671
@94.86 - New PB trap speed!
1/4 -
12.125@105.79
Third Run: Data and plugs looked great, swapped in the 300hp jets, left the #9 plugs. dropped target A/F to 12:1 while spraying (not counting ethanol modifiers), Reduced total nitrous on time to 6 seconds, 14° of timing pulled.
60' - 1.797 - Best 60' since the regear and bigger tires!
330' - 4.819 - New PB!
1/8 - 7.477
@89.94 - My trap speed dropped because the nitrous cut off 1 second earlier.
1/4 -
12.149@101.14
Fourth Run: Data looked good but #7 and 8 plugs were missing their ground straps
. I talked to someone from the speed shop I get my nitrous from and made some changes. 350hp jets went in, pulled 17° of timing, 11.5:1 target AFR, 10% additional fuel and 1° additional timing retard to #7 and 8.0, also nitrous run time was dropped to 5 seconds total.
60' - 1.766 - Best 60' since the regear and bigger tires!
330' - 4.713 - New PB!
1/8 - 7.278
@92.59 - New PB ET!
1/4 - 11.885
@101.89
When the nitrous comes on on the 350 jets, it's amazing. The front end is definitely getting light at this point, not sure if a tire lifted or not as I haven't watched the videos yet. Unfortunately as exciting as it is when the nitrous comes on, it's equally disappointing when it shuts down and I lose 40-50% of my power. I'm glad I cut it down to a 5 second spray or we would have definitely gone quicker than an 11.5. If I spray through the 1/8th I'm guessing I'd be in the 6's at over 100mph. Maybe we'll try that next time when Amber's driving, she'll just have to let off after the 1/8th so she doesn't go too fast.
Amber is still sleeping so I don't have the video's yet, I'll try to get them posted later today.
