Well, in a few months it will be.
Right now it's time for suspension questions ('cause I don't wanna be redoing this every year like @Deuling
). After last month's overlanding trip, I've decided to fix my camping suburban and I would like it to have more ground clearance than the K10. I don't want huge tires. I've been aiming for 33s. I wouldn't turn down 35s if they dropped into my lap, but I don't wanna be messing with hydro steering, probably not even crossover. I don't want anything that compromises reliability or durability. This is an overlanding rig, not a rock crawler. Trail performance is a good thing, but not as important as getting home afterwards. No death wobble, no huge amounts of body roll. I want to keep my street manners while adding a little more clearance and some tires that actually grab the ground instead of sliding around all the time. The stock K10 did nearly everything I wanted to do, so I don't need much. But while I'm at it I MAW grab some 42s and some portal axles and a couple ARB lockers. (sarcasm
Suburban thread is here if you wanna follow along this winter.
With that established, questions:
)Suburban thread is here if you wanna follow along this winter.
), so I'm not convinced that keeping them is a good idea. They're tired and saggy, and riding with the overleaf isn't helping the stiffness issue. If the stock 52s are wonderfully soft, why are you running the ORD springs in the front instead of using those?
