I'm not going to ream you, but I think coilovers are a bad idea for a few reasons. First is cost. I'm not putting thousands of dollars into this suspension at this time. If I could link my front axle for $700 (approximate cost of custom leaves) I would probably do it. But as it is links are a whole lot more expensive than custom leaf springs. Second is time. I'm impressed with your kit, but it's not something that I can install in 3 or 4 hours like I can redo the front leafs. Even the shackle flip is a fairly minor mod comparatively. I love links in theory, but this is neither the time nor the right truck for that conversion. Maybe when I have an actual shop with a FLOOR and crawling under the truck to weld brackets is funner. Right now this truck already needs a bunch of underbody work, I don't have much motivation to add a bunch more.
It comes down to driving style. This truck sees road miles, articulation is something that it has never had, and also something that it has never needed. Links are serious overkill for a roadtrip/expedition rig. IMO, at least. Thanks for the input, though. You made a good pitch, and I'll add it to the list of considered ideas.![]()
So there a hidden costs you may not be taking into consideration, leafs that are custom will stress every other area just as much as 52s would, so driveline, brake lines, steering, you need good shocks, u bolts. Etc.. While I wont disagree on the cost front because you are correct, but leafs that are custom are not a bolt in and forget it affair, if you are just after a better performing truck and would like to expend the least amount of effort than those ideas have been expressed, tuff country or superlift or skyjacker all make a decent riding leaf spring that bolts in, should provide 7-9 inches of vertical travel. All sell steering solutions for push pull. Heck that's what's on Ethel, she rides dang nice, still like a truck but not bad considering.
I find the push pull with the lifted arm to be ok at best because when flexed out on the driver side I can't turn right very far. It's a pain and I drive around that but it still sucks.
Your rig *looked* fine, but I never got in it, nor did I try loading up a baby in it. Again, I sure wish I had spent more time grabbing ideas from dunefest.
