There is a trick where you slide the pump gears together, then lay them on a smooth surface. If you can drag the outer gear with the inner gear, supposedly they are not too worn. You also check the side clearance with feeler gauges.
You are supposed to preload the center support one direction when you torque the bolt, I forgot which direction, I'd have to look it up.
