Whatchya building for BB17?
RIGHT ON
looks good
surprised ya'll cut the roof off, just easier and not needed I suppose.
The roof had started to crack at the A and B posts on both sides, plus the outside skin had been dented - lots of popping and creaking. Yes, it was easier to do the full cage by removing the roof. So, it was time for Poco Loco to "evolve".
I bought DOM to make new lower links.
I call that progress.
That is progress! Can't build them without the material!
Is that the issue with the Jimmy that you mentioned has it down right now?
Here's what I'll be bringing this year, hopefully my 73 will be done by BB18
2010 Jeep Rubicon Unlimited
3.5" ish Rock Krawler lift
Fox shocks and Steering Stabilizer
37x12.50 17's
5.13 gears
Poison Spyder Diff Covers
Teraflex front axle sleeves
Rock Krawler Tie Rod and Track Bars
LOD front Bumper w/warn VR8000
Crawler Concepts Rear bumper
DV8 Tube fenders and Tire Carrier
SPOD switch panel
ARB OBA
MBRP exhaust
S&B Intake
MBRP Off Camber exhaust
That is just the lowest part of the Jimmy that needs attention to be able to drive it. Figured I would start at the bottom and work my way up. Nothing is getting changed design or function wise. Just damage repair.
You've gotta get some of those 7075 links ordered. No more bent links!
More like an artificial sweetener momma. Just makes enough to live on, not enough to pay for extreme toy parts. Maybe the next wife.
37x12.50 17's
5.13 gears
SPOD switch panel
ARB OBA
MBRP exhaust
S&B Intake
Bought not built.... so sad. Hurry up and get the chevy done.
Ok,ok, i'll give you that. It's just the way you listed out the add-ons it sounds like a 4 wheel parts shopping list. Lol. Just bustin your chops. I secretly like jeeps myself. Shhh.
I shouldn't talk shit, i'm not even making it to BB
I expect to catch a ton of shit but this isn't my first BB....4 wheel parts shopping list nah....Its all from my place I run what I sell. I'll have another K5 one day but I'll rock the JK5 until I find the right one
I can tell I must be anxious for Blazer Bash. I keep checking CK5 every 30 minutes for build updates. Come on people, entertain me!
Man I'm going to miss this. :crazy:
OK....OK......Here's your fix for the evening, from me.
I finally got the steering gear box ported for ram assist. I'm on call 24/7 and this week has been busy. Just got it installed after a 21 hour day.
full
I should be able to finish the complete install and test it by the end of Saturday. And as long as I don't get called in to work I'll work on the brakes.
I got new, longer brake lines to go with the extra lift. And going to put in the larger master cylinder.
Only thing left after that will be the roll cage. I ordered the DIY4X kit with grab handles and the two side bars for the back. The cage kit should be here soon and I will post pics of that process of the build also.
And...............I'm tired. :yawn:
