Wife's 67 Power Wagon Build -Cage complete!
drive shafts
Shafts from High Angle.
1350 CV with parking brake at Atlas output, and 1410 at the 14bolt
1410 extreme angle CV, long spline, and 1410 at the Dana 60
Ho Lee Chit!!! This is the best evar!!!! What an awesome wife and rig!!!
I would give my left nut for my wife to A: Wear this, B: Work in the garage and, C: Wear this and help me work on my rig!
Unbelievable!!!!!!!!
Aluminum work.
Front aluminum inner fenders to reduce the weight of the tilt front end.
Makes plenty of room for access to the vitals.
Rear shock hoops.
These were same length as the fronts and designed to go up through the floor.
Box floor and mild "tub" job
we cut the 1" lip on the inside of the box where the arch is for the tire, and added a 4"wide strip to make room for flex and 42's,
Then the aluminum checker plate bed floor with a storage compartment.
Installed the LED tail lights.
Love how the big stuff shows more progress faster.:D
Relocation to new home and new XXL garage.
Eventually found a great big garage that came with a decent house, in the country,:D so we moved.
Now the finishing of the old Fargo was much easier!
You can see my original Burb still full length,
"new Burb" recently brought back from Pennsylvania, (soon to be cut up)
young lad's Heep,
and the PW.
New Man Cave is 40' x 100' wooohooo.
Room to burn a donut indoors!!!
Prime and paint the blue underside.
Used Blue Tremclad for easy touchup later.
Plastic walls went up later.
