Today was the first day that I drove my truck with the intention of putting it in overdrive and leaving it there. Made it to and from work just fine, albeit a little bouncy with no rear shocks.
I do have a few questions though, so I am paging the transmission guys...
@Greg Ducato @Blue85 and anyone else with knowledge...
1979 q-jet 350 with 1990 700R4 behind it. 4.10s, 38's.
I have no tachometer. My tires howl. Especially at speeds where OD and torque converter lock up should be expected.
I can definitely tell 3 distinct shifts, but I cannot tell if the torque converter is locking up.
I wired the lockup circuit as follows.
12V key on from factory fuse box under the dash to in-line fuse holder to the factory brake switch cruise control connection to the A terminal of the trans connector. I have not connected any other wires to the trans connector.
I confirmed with my DVOM that the cruise connection on the brake switch is closed normally, open while on the brake pedal.
I want to try and hook a light bulb in line to confirm the circuit is closing at speed. I am unable to hear the change in engine speed and have no tach to visully confirm. Does this sound like a good idea?
Secondly, I took my laser temp gun and scanned some areas related to the trans. These temps are after 20-30 minutes of idle time followed by a 15 mile drive, 12-13 miles of which were at highway speeds. Ambient temps were about 70 or 75.
Front of pan - 180
Rear of pan - 220
Cooler input - 166
Cooler output - 132
My cooler is a decent size. Not the biggest, but way bigger than any factory one and it is not routed through the radiator cooler at all.
I also should mention that the exhaust crossover (y-pipe) is a 1990 Suburban piece and runs under the trans pan.
The temps on the exhaust were 460 degrees.
For comparison, the 205 measured 130 degrees, and front hubs were each about 134.
Do these trans temps seem out of line for the drive home?
