Here is a before picture, this thing should be out soon.
Out the motor or through the motor?
:haha:
Out of the front timing cover seal, rear main, oil pan gasket, etc. It runs clean, passed emissions with a blown out cat, no blue smoke, just leaks.
I also figured out one of my leaks while putting the engine on the stand. It seems that the bolt that plugs the access hole to the fuel pump pushrod was left out.
Also, here is a few pics of my current electric fan setup. Used a couple 14" fans off of summit racing (I think they were branded under Mr. Gasket brand, about 99 bucks each), and a Derale adjustable electric fan controller, about 45 bucks. Then I bought a flat drip pan from the parts store and cut it up and bent it appropriately, riveted on some aluminum angle to make the upper and lower flanges, total price for everything was under 325 bucks.
Using the large drip pan is a pretty slick idea, nice work! I'm going cheap and using windstar fans later
My first set came from a junkyard Monte Carlo, but they died early...
