B
Bent77
Guest
He's going to get back to us. Minor SNAFU
Hehe. If thats the worst you doDid a nOOb mistake. Went to roll the cam and it wouldn't roll, forgot that I locked the fuel pump pushrod into place...
Well it freaked me out for a bitHehe. If thats the worst you do![]()
Yep, keep me posted on the cam lift.Definitely not worried about #4, yeah, there a some scuff marks, but nothing that I can catch a fingernail on, and this truck always ran good, even with the distributor 180 out.
Local yard had a pull-a-thon this morning, got a few things, nothing really exciting, came home and installed the new timing set. Looks like old set clearanced the block enough because the new set isn't rubbing anywhere. Still gotta get a battery for my caliper to measure my cam, there wasn't any markings on the cam to indicate something other than stock, I just want to be sure for the future TBI install.
Maybe, might just swap in the whole other engine after giving it a fresh up. That is all too far down the road to worry about it now.Yep, keep me posted on the cam lift.
Are you going to adapter plate the intake?
Those dont look like pistons@bent72 It took three stores until I found one that wasn't sold out... so I bought three.
Cam is stock.Yep, keep me posted on the cam lift.
Perfect TBI victim. Run the factory computer. Dump an O2 sensor in the pipe, few other trinkets and add a pump.Cam is stock.
