I could be wrong but I believe it starts with high idle when cold and a new IAC will need a few cycles reprogram the ECM?I got the kit in the mail yesterday and got the new gaskets installed. Both injectors spraying fuel now, and it idles smooth (no vibrations) but it idles FAST. Like damn I'd guess 1500+ RPM. Was just dumping white smoke out of my tail pipe too... filled up my garage with smoke.
Here's a video, sorry for the stupid zoom:
I want to check the timing, but they say you should do that with it warmed up. Don't know if I want to run it too long like this.
I don't think I have any vacuum leaks at this time but I should probably check again using the throttle cleaner trick.
As they say, it needs the cobwebs cleaned out of it.It might take a bit to clear out the O2 sensor.
He said I could pinch hit for him.As they say, it needs the cobwebs cleaned out of it.
@shima I'm in Denver this weekend if you want to drag race. I brought the big gun too. I promise to give you a couple of lengths.
Notes to self, just things I need to button up:
1. Reinstall the little heat shield plate / spark plug protector thing that bolts into the exhaust manifold on the passenger side.
2. Check oil level with dipstick. I am starting to thing my gauge doesn't work.
3. Set timing back to factory 0... although it seemed to drive great today as-is.
4. Take care of the small exhaust leaks where the manifolds meet the heads.
