Were you talking about using the rear u-bolt spring plates on the front axle?
Martin
Yea i was thinking of seeing if i could use the diy ones from the rear up front, and then order new ones for the rear 14bolt going in
Martin
I am merely a padawan in a sea of K5 jedi's..
IMG_8017 by Nick Smith, on Flickr
IMG_8018 by Nick Smith, on Flickr
IMG_8019 by Nick Smith, on Flickr
IMG_8020 by Nick Smith, on Flickr
IMG_8022 by Nick Smith, on Flickr
IMG_8023 by Nick Smith, on Flickr
IMG_8025 by Nick Smith, on Flickr
IMG_8028 by Nick Smith, on Flickr
IMG_8030 by Nick Smith, on Flickr
IMG_8033 by Nick Smith, on Flickr
IMG_8035 by Nick Smith, on Flickr
IMG_8037 by Nick Smith, on Flickr
So i started to fit up the inner fenders. They fit pretty good besides the passenger side inner body mount didn't line up but i will get back at it tomorrow, I was told to try jacking up the body mount near it and maybe it would bring it to alignment. The drivers side fit fine, I meant to measure the distance, from mount to mount on the inner fenders to see if it may just be a **** up with the fenders..?
IMG_8057 by Nick Smith, on Flickr
IMG_8058 by Nick Smith, on Flickr
IMG_8059 by Nick Smith, on Flickr
IMG_8052 by Nick Smith, on Flickr
IMG_8039 by Nick Smith, on Flickr
IMG_8063 by Nick Smith, on Flickr
IMG_8062 by Nick Smith, on Flickr
IMG_8064 by Nick Smith, on Flickr
IMG_8065 by Nick Smith, on Flickr
IMG_8068 by Nick Smith, on Flickr
IMG_8069 by Nick Smith, on Flickr
IMG_8070 by Nick Smith, on Flickr
IMG_8071 by Nick Smith, on Flickr
Try jacking under the core support a little. I had to do that to get my inners to line up properly and all the bolt holes to line up.
The rear axle has four equal sized u-bolts.
The front axle has different sized u-bolts for the u-bolt that goes around the pumpkin.
Martin
I was only going to use the plates, not reuse the ubolts. I like the look of the cast plates up front though, going to keep them. I ordered new u bolts and plates for the swap.
Looking good Nick!
You would have a hell of a time squeezing the top of the u-bolt at the pumpkin together to fit into the narrower spacing of the incorrect spring plate.
Seeing as you are keeping the stock cast plates, you don't have to worry.
Martin
IMG_8053 by Nick Smith, on Flickr
IMG_8055 by Nick Smith, on Flickr
IMG_8100 by Nick Smith, on Flickr
IMG_8102 by Nick Smith, on Flickr
IMG_8103 by Nick Smith, on Flickr
IMG_8105 by Nick Smith, on Flickr
IMG_8106 by Nick Smith, on Flickr
IMG_8107 by Nick Smith, on Flickr
IMG_8112 by Nick Smith, on Flickr
IMG_8115 by Nick Smith, on Flickr
IMG_8118 by Nick Smith, on Flickr
IMG_8119 by Nick Smith, on Flickr
IMG_8120 by Nick Smith, on Flickr
IMG_8121 by Nick Smith, on Flickr
IMG_8125 by Nick Smith, on Flickr
IMG_8127 by Nick Smith, on Flickr
IMG_8140 by Nick Smith, on Flickr
IMG_8147 by Nick Smith, on Flickr
IMG_8150 by Nick Smith, on Flickr
You factory 10b parking brake cables will bolt right into the 14sf
Well I cant speak for others but mine popped right inoh really? i had heard differently. The cable, and where they attach, do seem identical though
Its a long read so I tried to put together a table of contents of sorts. Hopefully some of my ideas and my lessons learned will inspire your buildI think i am going to be in the same boat as you, fingers crossed! do you have a build thread for yours?
https://ck5.com/forums/threads/my-official-restoration-thread-and-more.181502/
At least you didn't waste your day off! Nice job on everything so far!
