Oh it's earlier in this thread. 2002ish F250 ball joint Dana 60. And factory 1 ton springs up front.
Gearing?
What you gonna do about the different lug pattern? Adapters in the rear to swap it to match the front?Oh it's earlier in this thread. 2002ish F250 ball joint Dana 60. And factory 1 ton springs up front.
I'm drilling the unit bearings for the 8x6.5 bolt pattern. Got a buddy with a machine shop, and a water jet.What you gonna do about the different lug pattern? Adapters in the rear to swap it to match the front?
I see, that works since you got connections. If not there's a place called www.ezaccessory.com that sells 8x6.5 to super duty adapters for a reasonable price. Are you just gonna weld on new spring perches or set your spring width to match the super duty axle?I'm drilling the unit bearings for the 8x6.5 bolt pattern. Got a buddy with a machine shop, and a water jet.
Started on the front hangers a bit tonight. This being a 2wd truck, it required some frame cutting. Measured twice, cut once. I will end up boxing the front where I cut it to add back some rigidity. No clearance issues so far that I can see.
It's not yet, but it will be soon.
