There is no parts whoring, or other "classifieds" type stuff allowed in the Garage. Pony up and use the correct forum, or stick to Craigslist...
Rene
Rene
(to some degree lol)
But I will most definitely keep a eye out for NV4500 regardless if I find one in the next few weeks then I'll prob move on that, but as for now the 465 is my most cost efficient option. Also I saw earlier in this thread about a certian someone using a leftover hole (I think for some kinda electronics?) from the automatic transmission to put the external slave cylinder into that hole and he said he had no issues, I think it was page 2 or 3 I will have to look into that. And thanks for the tip about the new pedals, that's really not a bad price for that whole setup bran new.
First things first, your 95 has an IFS front end, which requires a driver's side drop transfer case. The NP208 you picked up will not work in your truck. That said, if your existing transfer case has the correct spline count, it will bolt directly onto the back of the SM465. Since that is the case, you will not need to worry about the speedometer.
You can buy all the clutch pedal stuff new from GM still, and it actually isn't horribly expensive either, under 400 dollars for everything you need brand new. Since you have a 32 spline transmission, I am quite certain it will have a hydraulic clutch on it. That said, it is an external clutch slave and is on the driver's side of the truck, right where your driveshaft will need to be, not to mention that there will probably be a difference in displacement between the two, meaning you'll have to find some way of adapting the older master cylinder to the newer truck's pedals.
I would personally suggest you look into buying an NV3500 or NV4500 5 speed manual transmission that would have come stock in your body style of truck. It will save you a number of headaches and will not loose you your overdrive gear like the SM465 will.
The SM465 really is more of a dump truck transmission anyways. Doesn't drive very nice.
Don't know if this has been stated yet, but his '95 1500 will NOT have a 32 spline transfer case... It will be 27 spline.
It is, however, a NP241, so you can swap the input shaft and everything attached to it, from a 3/4 ton 241, and then it will be 32 spline.
Also, his 27 spline tcase only has 3 planetary gears surrounding the input. The 32 spline cases have 6.
On another note, my SM465 drives and shifts very well. It has about 80k on it, and I have no problems shifting it as fast as any other manual trans I have driven.
Of course, my opinion is bias, as I would always choose a manual over an automatic in a truck.
Alright everyone some updates so far on my situation
The Transmission is from the 79-87 era (Cast iron top as opposed to aluminum top), 32 splines coming out the back and its bolted to a 208 aluminum transfer case. I have all the parts with the transmission, shifter, boot, ect ect.
No, he means top cover. The SM465's in the IFS trucks have aluminum top covers. The 1981-1987 half and three quarter tons use a cast iron top cover (shifter tower) and have a 32 spline output. The 1973 - 1980's use a cast iron cover with the 10 spline output shaft.
Martin
