B
One of the issues I had while sitting on the hill was that after a few minutes the fluid drained to the back of the trans and I lost all transmission function. I'm assuming the torque converter was basically empty. As soon as I was back on flat ground it was fine, but it was super frustrating at the time.
Is there any way to prevent that from happening in the future?
MAN Trans. Beat you to it @Bent77
I know you guys are all jealous of my stock bump stops that I'm too stiff to need along with my 30 year old rancho 5000s!![]()
I got a stock Chevy steering wheel from @Wicked Wolf Auto awhile back, so I decided it was time for an upgrade. I've been using this tiny grant steering wheel forever.
This one is a more appropriate size.
Unfortunately I'm having trouble figuring out how to hook up the horn button. I think I might be missing some pieces.
I have this:
And this on the column:
The parts in my hand came with the wheel, but there is no hole for the horn electrical lead to stick up like I have on the column.
Anybody got a diagram, or pic that can show me what I'm missing?
I was thinking about giving @ashman grief about not having the stock column or steering wheel in his!!!Is the column stock first gen? Curious if that later model steering wheel horn will actually be compatible? Those parts look similar to the first gen so may work. But on a first gen column that wire that sticks up is just a metal bushing/brush with a spring under it that forces it to contact the metal ring. I think LMC has a diagram.
I think I found the issue with connecting my horn button. I think I need this:
https://www.napaonline.com/en/p/NDP...tact+Repair+Kit&keywordInput=horn+contact+kit
As you can see in the image I posted earlier, my horn button ring has a wire lead sticking out. It's been so long that I didn't realize that was part of the adapter for the grant steering wheel. Once I replace it with the kit above, everything should install correctly.
yeah, until I saw a video of it going together I didn't catch the difference. Thanks for the help, even though I didn't understand it yet. lolYea, that’s the spring and brush thing I was remembering.
I took her out for a shakedown run before blazer bash and found my steering rod ends were bad. I have cross over steering now, so I couldn't figure out where the ends came from. Anybody able to help?
Left hand theads:
Right hand threads:
