Big tires and hubcaps absolutely rock!
It looks like the incoming pipe needs to overhang by maybe 1/2 of it's diameter as well (Approx 1.5")... if the diagram is really drawn to scale.It seems to me that is very similar to a hemholtz.. With regards to the setup and sizing it properly I'd be more inclined to get it running and tune from there, you are likely to end up with some strange resonance that could be deafening.. I was not sold on resonators until recent, I removed the intake resonator on my 6.2 and just about went deaf, it still has an audible resonance but it's much more reduced and live able.. The funny thing is those black widow mufflers use what looks to be similar to the principle he suggests, they are triangular inside the case.. I wonder if pairing one of those with a nice large case magnaflow or dynomax would eliminate any drone.
Better get Engine Masters on You Tube involved with this discussion. They just tested 2 1/2" vs. 3" exh with the exact same system and bends and guess what the 3" made more power and it was louder, imagine that.
I remember the good ole days of high school when burned out glass packs that popped and cracked on deccel were badass!!! My old '82 chevy 3/4 ton would back fire once in a while with dual exh that dumped before the rear axle and spit out a big fire ball at night. So much fun when you didn't give a shit about noise and drone and all that crap.A 2.5" system is too small for that engine, to be honest I was suprised it was less than 30 hp, as at the track you might see a worse difference than that at that level. I can pick up 20 hp on a little 425hp 388 SBC by uncorking the 2.5" exhaust to 3" open collectors, surely a 550 - 600 hp motor needs more than that. Heck at your level, if you have a 3.5" collector I wonder how much you would pick up with that vs a dual 3". But I think a dual 3.5" would be way too loud for little gain. A 3" is a good compromise.
And although it's fun to measure the dyno numbers, I would rather see 60 ft times, ETs, trap speeds, etc. That is a measurement of what you feel, not what a dyno feels. That system was also extremely long, like limo long. And it had two 45 degree bends for tailpipes, thats it. It looked like a mock system that wouldn't actually fit in anything. They both may have peformed slightly better in a better length.
One other thing you can't hear on a dyno is the sound when you let off under engine braking. It can sound real nice and smooth or sound like barky popping crap. Small long tailpipes exaggerate that.
Check this episode out for a surprise...
