Not many of us can say we have Cthulu exhaust, especially that we welded ourselves.
-- A
-- A
I remember the good ole days of high school when burned out glass packs that popped and cracked on deccel were badass!!! My old '82 chevy 3/4 ton would back fire once in a while with dual exh that dumped before the rear axle and spit out a big fire ball at night. So much fun when you didn't give a shit about noise and drone and all that crap.
Check this episode out for a surprise...
Yeah...saw that one. Left me feeling conflicted....
On the one hand, it made me feel like primary tube routing and shape is pretty forgiving after all... So the fact that my primary tube lengths are sometimes almost 6" different from each other (worst case) my engine will still start and idle properly.
But is also left me feeling like I spent 100 hours building "eye candy" that won't perform any better than if I'd screwed together a bunch of black pipe and cast iron elbows from Home Depot.
-G
Fortunately (and unfortunately) at about that same time, the truck was SO high up in the air that the back of the rollcage hit the ceiling joints. This allowed me to use the ceiling to "push down" on the back of the truck so that it was actually resting on all 4 jackstands instead of just 2. But as you will see.... I came up just a little short as a result.
) In the interest of progress, that section of fender was removed and the axle was brought ALL THE WAY to the maximum articulation. I liked that the top of the tire actually "tucked in" behind the fenderlip instead of hitting it. The only bummer was that on the droop side of the axle I ended up about 1" short of getting full-droop... so the angle of the axle (and it's relative clearance with the frame /fenders, etc. is not 100% accurate.
That's some pretty snazzy zebra carpeting in your garage! Your truck is pampered!
(It's also softer to smash into when falling off a ladder.....allegedly)
agreed. Less is more in this case. Too much flair would certainly ruin the "stock" look you are going for.It would have been nice to push the flare out even further (3" or more) but I am afraid that the look will end up being too obvious and noticeable as an "add on" to the truck.
-G
Does your locality have any issues w/ the tires being exposed?
Definately no longer stock, you need to sell the rig quick now.
