I'll be checking the motion of the axle when trying to articulate the springs, and take my measurements when I can get it compressed and extended.
I still need to work out the pinion angles too.
I have looked at those air stops for bumps, but just too much money right now. I figure more suspension mods will be a ways out in the future. Just need to get the basics up and going right now. If I waited to get everything the way I wanted it, I'd have to sell some other toys....cant do that.
Anyhow today I got the trans finished up, at least enough to clear the bench of trans parts now, and move on to the transfer cases again.
Ready for use in the mockup phase now:
My TH400 build includes the following:
Rebuild with new steels, and fibers, nothing special here just a transtar kit.
Replaced all 3 stamped steel pistons with cast aluminum ones, which replaced the plastic spring retainers also.
Coan Reverse Pattern Manual Valvebody, with engine braking (looks to be a Cheetah unit).
New rear band, new front band,
Upgraded 34 element intermediate sprag assy, and new direct drum for the 34 element sprag.
Removal of direct piston middle seal, intermediate pump 2nd seal, and plug of the corresponding valvebody passage in the case, to allow more holding power to the direct (high gear) clutches.
Thick intermediate case spacer ring.
Rear roller thrust bearing, replacing the stock thrust washers.
And I got the finishing touch for the D60 today, along with some custom frame brackets for tiedown anchors all from the crew @ DIY4X.
