The truck is a beast, glad you are reunited
Aren't the cage tie ins supposed to the other way? It seems like your current setup is just a pivot
I also plan on making an anti rotation plate on the front cage tie ins, it will be a flat plate that goes from the flat part of the body mount to the tube so that when pushed down it will not rotate around the bushings
there has been a lot of debate about which way to mount these...from the many trucks I've rode in, my truck is as solid as any (perhaps you recall from riding in it?)...there is no body flex, no chassis flex...its caged from the rad support to the tailgate. With all that going on I don't think it matters in my case, which position these bushings are mounted in. Perhaps a simple roll bar, or small cage it might matter. I went by what the CK5er's were saying at the time of the build and greet. I don't think the discussion was as lengthy as the one about how long to make the traction bar though!
I think your fine too Dave, I definitely wouldn't change it at this point.
I was just saying, if Adam is making a set from scratch, he can move them to the bottom cage plate so the mounting plane is horizontal, then it kind of kills the debate, because the bolt can mount inline with the brace tube while also being able to lift the body off.
LOL. I kind of came up with a few ways I could have done them better since then too. I thought they did add something to them later though...
guess not.They're fine as is but I somewhat understand the concerns of what Adam might be getting into.
I had envisioned full cage front to back from the beginning and the rigidity that it provides is awesome
Only thing I would do different is tie in the sliders.
Like I mentioned with a full caged truck its not an issue, things stay put!
The suspension does all the flexing and it shows!
