I love that you still run the factory top. It makes it a bit of a sleeper.
David
I got my painted stuff put back on for this coming weekends recon trip. I am praying I have zero issues... I just want it to work and not be a problem filled day if I can avoid it..
I also found this mat when I was at Home Depot the other day and cut it to cover up the holes I had in the floor. Again I am hesitant to put in plates because I’m going to just end up cutting it back out. So this is a stop gab for dust ingestion. There will be a tire and tools on top of this and it’s a lot better than my duct tape mods before.. I also put a blanket around each shock that was cut to fit preventing further dust from getting in hopefully.
488EA216-5DD8-42D7-A97D-6943B9A424EC.jpeg C9646BBD-4DD3-44E1-8568-994022D88C61.jpeg F281BF14-2CA8-41FF-ADA1-C91ED2BFFE13.jpeg 83021E9E-685A-452F-B91C-CED529D2D41F.jpeg A904F3E1-9377-4BBE-A30C-CACBAC4EC571.jpeg
Got the re prep done, also identified a possible root cause for the axle seal debacle. The vent had a 1/16 hole and was not 1/4 like the fitting ID was so I drilled that out. I still have the fuel filter on the end to capture any vented fluid but hopefully this takes care of the expansion.
I also touched her up so she can be all pretty for her KOH and her new stickers
Thinking maybe we should change the company name??
376B3FB8-ECE7-4C61-B713-6E23DF465535.jpeg 98F3E8C9-B7F2-436F-B5B7-7985121B0C4F.jpeg C8060CC0-865E-4F77-A776-F39A07794BEF.jpeg E0171BB2-45AF-4E88-A0FE-12BA5E9A4FB7.jpeg
Boy that rig sure has come a long way. Remember when you wern't even sure it was ever going to be back together and running? One small step at a time and tons of perseverance and Ta-Da. Now all I need is a new Transmission case and we could hang out.
What case do you need? I may have a source
Remember when he was going to sell it?
