A loose negative terminal will be the last thing that stops this thing. Every damn wire has been checked multiple times with the EFI bugs I worked through.
5.13's in the 60
Ram is mocked up
I can take more pics when I take the cover off.
I debated on whether or not to say anything, and with what I have seen in the past you would probably be alright but I thought I would cause I don't wanna see you break gears. Rather they last forever
I paid a professional to install the gears, he's well known in the area. Critisism is welcomed.
Sorry dude, that is simply put not an acceptable pattern.
Pinion is too deep.
Here is acceptable stuff.
Here is too deep
With that sharp line on the bottom of the gear it's obvious.
Since those are front gears it will likely never be an issue. But the simple fact of the matter is those gears we're not set up properly
I really need a pic of the drive and coast.
But I wouldn't send a set of gears out like that
