ummm & and dilemma question ?
they didn't think someone with a 3/4 ton would want to go faster ? or the 6.2 can't handle going that fast ? ... I'd think the motor wouldn't care, it could have 8 speeds and it would run fine and at a lower rpm ... done with that rant ...
now onto ... my latest dilemma.... My oil pressure guage doesn't work now, ( stock one ) , have an aftermarket one on top of the dash, that works fine. The voltage meter stopped working ( but when tested with a dmm ... it reads 14.38 on both batteries, so I know the alt is charging, and odometer never worked, and the fuel gage sows empty , but is full of fuel.... I swapped out the one and only 20 amp fuse for the guages, but to no avail .... so what else can I check ? do I replace the wires for each or find a new panel ? or just get new aftermarket guages, etc. ? Or do I swap out the fuse block ? The odometer I really don't care about, but monitoring the voltage and the fuel are the most important to me !
Any Suggestions ?
