It’s like your begging for a reason to head out to the desert in the AT4 lolHave a tow rig and trailer.
Back of the truck, all goodWe got n problem if he wants to come find us. My garmin will be on. Though he’s gonna have to figure out his own sleeping arrangements.
Offering a brother some help if needed, but wouldn’t be against itIt’s like your begging for a reason to head out to the desert in the AT4 lol
Pima was really cool.Xmas day progress. Since the family get together didn’t start until the afternoon I got some needed stuff done this morning. Oil changed and found my exhaust leak. Both sides at the flange to the pipe was loose. Each side. Not crazy loose but enough you could hear it.
Truck is partially packed. Laundry in the dryer so I’ll pack my clothes tonight.
Target location has changed. Rain has hit Death Valley in the last couple of days. Moving to plan b. Southeastern Arizona. Bomb around the desert, maybe go to tombstone. Might end up near Pima air museum and check it out. Nothing really set in stone. Just depends.
I’ll have my garmin fired up and shoot the link for anybody that wants to follow.
We saw that and that’s part of why we wanted to go. We are going to work our way in the direction.You might be missing your only chance to see death Valley with/as a lake.
Enjoy the trip either way or any place you choose to see
I did. You missed the link in the post above yours where I did a day by day report as we were going for the most part. A little different than I’ve done before. Just click on “adventure” above.Make it back?
Martin
Any thoughts on making the exhaust a heat exchanger of some kind? Also, can it draw combustion air from outside? Drawing it from inside just brings more cold air into the camper.Got the exhaust pipe covered up with exhaust wrap. Exhaust outlet reinstalled on the camper body. Tidied up the wiring and gave it another test run. It’s unseasonably warm here today as the temps were in the high 60’s. But within a 1/2 hour of running it using my temp gun I was seeing surface temps on the opposite side of wall of the camper near the roof (top down) were in the high 80’s. I did put the 90 Degree elbow on the outlet so now the outlet goes straight into the interior instead angled right at the fridge.
I spent a good chunk of time checking temps of the exhaust and make sure nothing is in danger of getting torched. The wrap does a good job keeping the pipe from melting anything near it.
I studied the manual to figure out how to regulate the temp/fan speed but my chinesium translator seems to be on the fritz. I’ll probably end up ordering a different controller to be able to run it in true thermostat style.
I’m sure one could use the exhaust as a heat exchanger. Partly why I didn’t hear is the pipe without the wrap got very hot. Like well over 200 degrees. Since I’ve got the heater mounted to a wood structure I was concerned with it catching fire from the pipe.Any thoughts on making the exhaust a heat exchanger of some kind? Also, can it draw combustion air from outside? Drawing it from inside just brings more cold air into the camper.
On the RVs I've had, you had to be careful walking past the furnace exhaust. I'd be surprised if they were more than 60% efficient.
For sure that happens at some point - the question is how much is OK. Maybe a couple of bends would be OK. Removing the heat wrap and replacing it with a heat shield would theoretically put more heat in the camper. Maybe it's not worth overthinking for occasional use.Running the exhaust through a heat exchanger would restrict the air flow enough to stall combustion one you don't remove the exhaust fast enough.
Honestly, if the camper was a bigger space the little diesel heater might need some help. But seeing how the camper interior space is so small I had to shut it off. If I had it running 3-4 hours it was easily 80 degrees in the camper. That’s running it on a lowest setting. Since mine doesn’t run a true thermostat style system it just gets warmer and warmer in there.For sure that happens at some point - the question is how much is OK. Maybe a couple of bends would be OK. Removing the heat wrap and replacing it with a heat shield would theoretically put more heat in the camper. Maybe it's not worth overthinking for occasional use.
I’ve already got a 7,400 pound Blazer, what’s another 150 pounds of cast iron added into the mix?This guy runs the exhaust through a giant cast iron radiator.
Plus the space it would eat up.
