Are you asking tube size to compare for aluminum radiator shopping? Because I don't think they set up the same way at all.
I don't know to sizes, but generally speaking, copper/brass radiators tend to have smaller tubes and more over them. While aluminum units have larger tubes and less of them.
Like an all aluminum 2 row radiator is comperable to a 4 row brass/copper for the same overall size. I'm sure there are some articles or web posts of direct comparisons between the two, but I'm going off of memory while I scarf down my lunch.
Just a sammich and some chips. Same as the day before.Important clarification.. what's for lunch?
Did you let magic smoke out?I drove this pig for about 45 mins. Was averaging low 200s even at lights. Highest i saw was 206.
One weird thing... now im smelling a burning smell in the cab, like electrical... could also be trans fluid burning off the exhaust... could be that i used gorilla tape to seal my fan shroud to my radiator just to test a theory.... hmmm... not sure, really smells electrical.
I removed the gorilla tape ill see if that was it.
I think it was hopes and dreams smoke...Did you let magic smoke out?
Mine looked like that put a 2x4 in the middle of it and me and my son hung on each side a little till it was spot onI'm trying to avoid a hood that fits like this one![]()
no more room under there, that trans cooler is massive... i could do a different remote oil cooler with a dedicated fan, that would be a lot of fans on this truck lolCould you mount it down low like the transmission cooler? Otherwise you're just defeating the purpose of moving the transcooler away from the radiator.
