Friday when it was raining I might of been at the neighbors.I went past your spot a couple times at the swap meet, but you weren’t there to say hi.
It's rolling for the first time since the last time, bumpstops cans and link frame mounts need welded.
I'll probably weld it to the plate on front of head that I had for limit straps, AC is on a list of things for next winter. It's time for test spin and wrap up this project for the summer.Did you get the A/C mounting more securely mounted? Do you have more details on the setup? I’m needing to do something like that on my 6BT.
I used 3M seam sealer to fill between frame and plate. The engine bay sparkles with fabricating dust so before opening intake tubes and other vital organs it'll get cleaned.
