Those little M12 tools are pretty decent. I really like the screwgun. Impact didn't do all that bad either re-roofing the shed.
I need that!Been on a bit of a tool bender recently. I got sick of losing the splined sockets for the lug nuts on all the cars so I bought a boxed set that covers at least all the different ones I need them for. Now to make sure each vehicle has the correct one with the spare and tire change tools.View attachment 489766
I got tired of trying to find the ones I kept in the glove boxes after I would use them to work on whatever vehicle that has them and all three are all different. This set will get used at home and the ones in each vehicle are for roadside use.I need that!
I have a set on the K30 that I thought took the same key as my 2500 burb.
Turns out that it doesn't and I can't find the right one![]()
Vevor i believe is Chinese so it should be cheap but it is decent quality from what I saw with my vevor rv heaterYeah basically. It is a hydraulic hole punch as an assembly. Vevor ch70 which is extremely affordable compared to the other higher end machines.
