Got any cool tools lately?
Those little M12 tools are pretty decent. I really like the screwgun. Impact didn't do all that bad either re-roofing the shed.
Well, I tried the drill trick and I didn't like it much for small fasteners. So I bought this thinking it would be great for clearance issues when the need arises. Not only does it have much finer torque control and feel, but I found another benefit vs the drill or impact driver, when you are not on the trigger, the bit is locked, so you can manually crack fasteners loose and then hit the trigger and remove them, or you can tighten them and then give it the last snug by hand without the motor, that doesn't work with the drill or impact.
271b6ea664bf42beabe7d2a57083adea
Was checking out CL and came across this old Smithy three in one setup ,got some tooling,the Plum Crazy painted wheeled stand,quick change tool post,have added a lot of tooling , especially for the mill.
And yes the DRO was included ,it was an add on done by the previous owner.
Thats neat, there's been several times where I wish my lathe had a milling head on it too.
Been on a bit of a tool bender recently. I got sick of losing the splined sockets for the lug nuts on all the cars so I bought a boxed set that covers at least all the different ones I need them for. Now to make sure each vehicle has the correct one with the spare and tire change tools.image000000(12).jpg
Been on a bit of a tool bender recently. I got sick of losing the splined sockets for the lug nuts on all the cars so I bought a boxed set that covers at least all the different ones I need them for. Now to make sure each vehicle has the correct one with the spare and tire change tools.View attachment 489766
I need that!
I have a set on the K30 that I thought took the same key as my 2500 burb.
Turns out that it doesn't and I can't find the right one :doah:
I need that!
I got tired of trying to find the ones I kept in the glove boxes after I would use them to work on whatever vehicle that has them and all three are all different. This set will get used at home and the ones in each vehicle are for roadside use.
Yeah basically. It is a hydraulic hole punch as an assembly. Vevor ch70 which is extremely affordable compared to the other higher end machines.
Vevor i believe is Chinese so it should be cheap but it is decent quality from what I saw with my vevor rv heater
