Done yet?
AlmostDone yet?
Most definitely I’m just gun shy I guess now after cracking the frame .Extend your cage work into the engine bay to reinforce your frame, tie that into your coilover mounts. I don’t see the point of boxing if you do that.
Im worried about the left to right movement of the Axel seems to put a lot of stress on the frame where the links mount . I’m definitely going full hydro steering but I think I should get the motor in and see how that’s gonna fit and start building around it I think lol.
It’s photos like that one that got me to add a handful of gussets and jungle gym out the engine cage. Fingers crossed that it’ll work.
David
Ord sells a kit for the front I’m doing the front now .For a sway bar, starting with a rear is simpler to assemble and might be all you need. That’s where I notice the bulk of my roll, albeit with a heavier truck.
David
Talked with ord today gonna put the sway in the rear and get setup with a soft tension bar . Also got the link brackets tacked to the axel and c-clamped to the frame .
Pics are coming keep your pants on it was late lol
