Stomis
Professional Amateur
Lol throw by the magic invisible coilovers til I saw that beast jackstand lol
I like the truss...
Where did you pick up the joints???
I used these brackets so I can fine tune my rear link suspension.
You'll more than likely need to triangulate your lowers to get oyur roll axis in check.
I was playing with the numbers and it definately needs to be double triangulated. I could get nnumbers from -2 to 2 easy
Those two ballistic are 30 each and then I need to get some tabs for the rest
Do you have any pics of your lower crossmember, looks like I'll be doing pretty much what you have
How long are your links?
That hangs pretty low, have you crawled with it yet? Have any problems hanging up on stuff?
Those upper chassis brackets are from poly performance.
I'll have to get a current pic of the crossmember since I tied it into my tranny/case crossmember.
My lowers are 51" eye-to-eye. Pretty long but about the best way to do with the wheelbase I had to do with the ext cab and frame shape. Hence why they are 2.5"x.5" DOM.
I don't see that thing as a crawler.
IMO just save up and get the good joint from the get go instead of paying half the $$ for a temp. They runs sales from time to time too.
I got my inserts and jam nuts from ruff stuff, much cheaper than ballistic. Also budget in or borrow a tap to clean the thread of the insert after welding. I got a 1.25" hand tap for $30 on ebay.
Ouch 340 dollars worth of brackets tabs and joints
