I don't know that I'd obsess over half an inch.
You didn't read my text correctly, both of our trucks are at the same height right now, just mine is 58" on the driver side. But I don't have the spare in it right now, no rear bumper or anything in the back besides the seat. The winch is still not installed and I put a zero rate in the back because it sat level with only 5 gallons in the tank. It is currently almost full. I don't know why it's this tall, but I still had to cut a decent amount of fender to clear. Time will tell I guess.no, jerk....
We were discussing truck height. He measured his at an inch taller.
The doors between a 77 and a 90 are the same right?
I don't have plans for a carrier yet, but I believe that I can add one if I change my mind later. I haven't convinced myself to hang it on the bumper yet, I don't care for it much. I may change my mind later and be cranky about not doing it the first time.Looks good so far! You going to build a spare tire carrier for it?
Maybe you text like a dorkYou didn't read my text correctly, both of our trucks are at the same height right now, just mine is 58" on the driver side. But I don't have the spare in it right now, no rear bumper or anything in the back besides the seat. The winch is still not installed and I put a zero rate in the back because it sat level with only 5 gallons in the tank. It is currently almost full. I don't know why it's this tall, but I still had to cut a decent amount of fender to clear. Time will tell I guess.
Mine leans because of the rear springs, (used) , I proved it last summer and swapped them side to side and the lean followed. I made it sit high on the driver side since.I don't know that I'd obsess over half an inch.
Oh, right.. cuz you get confused of which is left (driver) and right (passenger).Maybe you text like a dork
You're a half inch short...Oh, right.. cuz you get confused of which is left (driver) and right (passenger).
I should expect that from you.
no, jerk....
Yeah should be. Mine just measured 59.5 passYou still did read the text correctly. Put your glasses on, then zoom in.You're a half inch short...
Mine is loaded, half tank fuel. Tools and spare, w/ winch
But the difference in the tires sizes plus springs should add up more.
Maybe your springs haven't settled?
I'm loaded
Short Dave is trying to figure out why he can’t get it in
Sorry, I'll go away now
5.5” lift 52 ord’s@Fastereddie what springs you have?
5.5” lift 52 ord’s
No bodylift, but 40’sBody lift?
I feel his pain, it's cool short Dave, I'm short too.Short Dave is trying to figure out why he can’t get it in
his truck
Thanks buddy!!I feel his pain, it's cool short Dave, I'm short too.
