no, jerk....
We were discussing truck height. He measured his at an inch taller.
The doors between a 77 and a 90 are the same right?
You didn't read my text correctly, both of our trucks are at the same height right now, just mine is 58" on the driver side. But I don't have the spare in it right now, no rear bumper or anything in the back besides the seat. The winch is still not installed and I put a zero rate in the back because it sat level with only 5 gallons in the tank. It is currently almost full. I don't know why it's this tall, but I still had to cut a decent amount of fender to clear. Time will tell I guess.
Looks good so far! You going to build a spare tire carrier for it?
I don't have plans for a carrier yet, but I believe that I can add one if I change my mind later. I haven't convinced myself to hang it on the bumper yet, I don't care for it much. I may change my mind later and be cranky about not doing it the first time.
Maybe you text like a dork
I don't know that I'd obsess over half an inch.
Mine leans because of the rear springs, (used) , I proved it last summer and swapped them side to side and the lean followed. I made it sit high on the driver side since.
Oh, right.. cuz you get confused of which is left (driver) and right (passenger).
I should expect that from you.
You're a half inch short...
Mine is loaded, half tank fuel. Tools and spare, w/ winch
But the difference in the tires sizes plus springs should add up more.
Maybe your springs haven't settled?
no, jerk....
:haha:Yeah should be. Mine just measured 59.5 pass
And 60” driver.
You still did read the text correctly. Put your glasses on, then zoom in.
But remember that I have the 1" body lift. I don't know where things got confused when I ordered the front springs, but it really doesn't matter since it stuffs the little 37s like this without getting to the bump stops.
:haha:
Sorry, I'll go away now
Short Dave is trying to figure out why he can’t get it in
his truck
Seems my truck doesn’t sit much higher than his despite shorter lift and shorter tires
One of you is measuring to the bottom of the black button and the other is measuring to the top of the shiny handle. There, mystery solved.
The point is height with different springs and such.
Mine has sacked out 52s
