linked one ton escalade (coming back soon)
I wanted to the other day but I needed it done. Took 4 hours to replace a starter....
Stick with it Dan
doesnt look bad at all, but i smashed it at the same time. its also not near as bad as when i put a utility knife through my thumb when swapping seats in the blazer.
Trimmed a little more, left an inch inside the line and the notched it and folded it in, it looks decent, forgot to take pictures after its folded in. the wheel well looks huge, but im hoping when i put the round tubing on the inside of it and a little bigger tire it looks better.
The left is at full bump, the right still has maybe another inch or two of droop. there is about 20 inches under the tire.
also need to start on the shock towers, should i just do a simple tube shock hoop with a bar across or something different? also planning on running something to connect the top of the shock tower out to the tubing that goes around the wheel well. if that makes sense
well holy shit king 2.5 inch bump stops are expensive. who has some new ones in the box they want to sell me cheap?
