Put the bars back on.
It seems personal at this point.How do you know? Have you tried it?
Drill the hole out slightly bigger then plug with a sheetmetal plug.
The larger hole allows you to fish out the nutsert.
I have given you more then enough options, but your just arguing to argue.
The thing still has rust holes and dents and you're hung up on whether or not there are attachment points on the roof? I mean, it was your idea:How do you know? Have you tried it?
Put the bolts back in with some rubber washers until you get body work done to fill them correctly.
Sure you can see them up close but going down the road it's cleaner looking.
