LSX454 swapped 95 BASS burb.
Little lower, little cooler, bigger sounds.
What could have possibly vibrated that nut loose?
Sound Bass GIF
That’s intense if the subs caused it.
My engine vibrates everything loose, your stereo does the same. The loudest system I ever built was only about 140db, I'm guessing you're way beyond that.
That nut just might not have been tightened correctly when the trans was buttoned up.
