ion
I'm not playing with it until other things are finished up.
Yeah, I've said that to a few ex's in my time.
I'm thinking crap in the axle tubes is a 14bsf thing. I had a lot of muck in my tubes. I tried to clean it out but couldn't get it alll and had to go through a lot of gear oil to flflush it all out.
Pattern looks perfect!
Its almost like you've done this before...
Yeah, once or twice.
There isn't a ton of crap in there, maybe most of it is surface rust. But there are some chunks of loose stuff in there and it's a good time now to try and scrape it out. I have a length of threaded rod and some sheetmetal I cut into a curve to make a scraper, I just couldn't fit it past the bearing. Gonna try from the center and pull the pieces in towards the middle cause the outer bearings look good, no need to replace them.
Oh, Rich, just pick up some outer axle seals and you can install them whenever you reassemble. I can't figure out why the one side was loaded with RTV excpet that maybe the PO was slightly mentally handicapped during his removal/install procedure.
Other than that I am reassembling the pinion with it's new crush washer and pinion seal tomorrow night. The lock right is out of the carrier so you'll hafta put that back together. I think I still have the book for mine if you need to borrow it for reassembly.
To just replace? Easy, just need a press to do it if it's the inner. The outer you can do with normal tools. Either way, you should replace the crush washer and a new pinion seal. Only special tool you might need is an inch pound beam or dial type torque wrench to set the bearing preload. As well as adapters to go from 1/4 drive at the wrench to 1/2 drive socket.
The bearings are cheap enough that if you are doing one, you may as well do both. You have to remove the pinion to inspect them both anyways. Hope I answered your question.
Hey adam. I think I can find lots of fun things to play with right here at home.Hey brian. Come over to MI. ill give you lots of axles to play with![]()
But, if you want to pay for the shipping, send the axles here and I will install whatever gears in them for ya.![]()
