No, don't own one. Had this old thing for a long time. Principal should be the same. Unless there is something I don't know about the dial type? They just give you a reading through a dial face instead of the beam type shown, right?
What are peoples opinions on moving my axle back? How far? What are the pros and cons?
I am putting in easy inches and I have spring plates from diy that are drilled in a few spots.
Con: Disproportional or awkward looking
And your axle moves back under compression already. So just take that into account
I'm going to cut lots when I do my rear bumper.
I did, my setup up used an ez inch to move my axle reward after the shackleflip which allowed the outside corner of the plate to hit and eventually pop a hole in the shock body at full compression. I have since inboarded them.
Thanks, I'm sure you just saw my edit. I was mocking the shock up on the wrong side of the axle.
Looking good Rich![]()
We ran a few "new" trails at RC that you've got to try next time, Jacob even commented "Mr Rich would like this trail"
Did you ever determine what the problem/cause was with the steering ?
