We are starting to spin our wheels, and not in a fun way.
We need to try to narrow down what is vibrating.
If you have access to any smooth less traveled roads, you need to put two people in another vehicle, and let them follow you as you drive.
Try to impress on the other two, that one drives and the other looks.
It is just so natural for the driver to want to look too.
I got tired of being driven into ditches and almost into a tree, so I started carrying a small club and would threaten the driver every time he took his eyes off the road.
Drive down the road at the minimum speed that it will shake good at, and let the other car come alongside.
Then, move over if you can and let him come up the other side.
Pictures are not all that important for this, but if you happen to have one of those little flip movie cams, it might help to figure out what is what back at the house.
Things to look for:
One wheel hopping up and down. This would be an out of balance tire or bent wheel.
Front tires slamming back and forth side to side. This is called a Shimmy in mild cases and a death rattle around here.
If the whole truck is shaking, they need to try to get a good look at the rear driveshaft.
It will not be flexing per se, but the rear end and transfer case on each end of it will be kinda flopping up and down.
Just for fun, before you do all this, open the hood, crank the engine and rev it up about 1/4 throttle and look for vibration.
If you don't see any, let it go back to idle, put it in gear with the brakes held, and with the spotter standing to one side and nothing right in front in case the brakes fail, give it a little gas.
The engine should rise up slightly on one side. If it flops over and hits the fender, you probably have found the problem and most likely will need a set of engine mounts...
If he does the drive thing, anybody here have any suggestions for other things for him to look for??
J.
