Dont put any oiled filter on a dmax. The location of the maf makes them very easy to get contaminated with oil.
Looking at balljoints, I'm curious as to what y'all think are the best? I usually go with Moog, but there's other brands making a case for themselves, mostly in price. Or should I just stick with a product of known quality? (Moog)
Yep, ground on frame under driver side front door. Clean and rebolt with new nut and bolt.ABS and Brake dash lights together at random can be as simple as a ground issue, or as bad as a ABS control module. There's some youtube videos on the problem...
Not that I could see, just the oil lines. What would it do?Canister looks like a preluber. Does it have any electrical wires going to it?
All the fluids are getting changed as well as new filters all around.
This stuff?Go Transynd for the trans fluid. wont hurt to do a double change as well. Only problem is that is spendy fluid.
No. You want Castrol Transynd for Allison. TES-295 cert.
