May I suggest moving to the 7100 shock for the save of adjustability? I don't think you need a larger shock but I bet your on the cusp of that recommendation just because of the sheer mass..
That's exactly what Stephen and I talked about. There's a valving he's searching for that would tend to suit a heavy truck like mine, and save me going to a larger body and thus substantially more expensive.May I suggest moving to the 7100 shock for the save of adjustability? I don't think you need a larger shock but I bet your on the cusp of that recommendation just because of the sheer mass.
Very interesting. Are you using the remote start on your diesel? Does it have a delay for glow plugs?I'm running an audiovox prestige remote start in my Burb, and it's been flawless for years after I did the install. Even has 2 extra channels that I used for timer high beams
Yes. I think I'm headed down the same path. Thank you for blazing the trail.The shocks he had me put on my SAS diesel were the Bilstein "Super Duty" series as he put it. I wonder if that's the same ones.
David
the charger, and whatever customer project is in the shop
I've built it ten times in my head. Working toward the real thing.Speaking of the charger...
I have the full replacement certs, so they should. That program has always worked well for me. On one hand, I curse the dude who isn't adult enough to keep his stuff together and not spill parts in the road. On the other hand, I'll get a new tire from this.reminds me of the time I got a hammer claw wedged in my tire. Discount tire will warranty this right?
. That could have been a lot worse then just needing a new tire.
