Post lots of pics of the upper shock mounts installed, I'm curious to see how they work out.
I have no clue, i imagine it would be easy to add a little drainDo those inner C supports have a drain hole anywhere on the top shock mount portion?
The only thing I know you lose is length for the shocks but since you are using a taller upper mount you are compensatedI never go in the mud and my trucks almost never see wet conditions. they sit in the garage most the time.
Anyone that has switched up their front shock mounts.... are there any real pros or cons to mountingthe shocks directly on top of the axle and running the front shock perfectly straight up and down?
It works fine. I cycled my suspension to find the center of forward to rearward shackle movement and that’s where I have the bushing straight. So It twists an equal amount throughout the spring movement.I never go in the mud and my trucks almost never see wet conditions. they sit in the garage most the time.
I've mounted my shocks like that for years and I've not used a sway bar for the same amount of time. I think the vertical shocks help with body roll, mind you they don't do as well as a sway bar, but well enough for me. Truck doesn't feel unstable. I also use good monotube shocks.I never go in the mud and my trucks almost never see wet conditions. they sit in the garage most the time.
Have you looked inside your rock sliders yet? asking for a friend
I swear I noticed the front end felt "softer" and more sloppy after I did the ford shock towers... maybe its because of the angle I have them at?I've mounted my shocks like that for years and I've not used a sway bar for the same amount of time. I think the vertical shocks help with body roll, mind you they don't do as well as a sway bar, but well enough for me. Truck doesn't feel unstable. I also use good monotube shocks.
I cant tell but do you have a gusset on the backside of the ford tower tying into top of the [ frame. That helped mine flex less because it tied the mount into the frame in 2 different directions. I also put 3 bolts in the ford tower for the same reason
I can't find the visual for it but the more you lay the shock back the less mechanical advantage it has to do its job. To me it looks like your front shocks are slanted back pretty far.I swear I noticed the front end felt "softer" and more sloppy after I did the ford shock towers... maybe its because of the angle I have them at?
They lean pretty far back
I will say the extra travel was amazing and I only want to switch things to get just a hair more up and down travel and make it feel a little more stable...
