Well, adjusted the drivers door one last time and as luck would have it, striped one of the nuts in the door, had a feeling that would happen taking the door off and on about a hundred times. Don't think it's a big deal as there are 2 other bolts holding that hinge and it's the lower one, but would like to fix eventually. What would be the best way to fix, run a tap through it and see if it will clean up?
Always try that first. But Greg has a point...Well, adjusted the drivers door one last time and as luck would have it, striped one of the nuts in the door, had a feeling that would happen taking the door off and on about a hundred times. Don't think it's a big deal as there are 2 other bolts holding that hinge and it's the lower one, but would like to fix eventually. What would be the best way to fix, run a tap through it and see if it will clean up?
Take the door off and apart and replace the plate.And that point is?
Duct tape?On a happier note, got the horn working.![]()
Umm no.Duct tape?
Pretty muchTwo steps foreward and all that.
And that point is?
