But this truck actually exists on CK5....
Unlike 100PPP.
-G
Done.
So, one of the PO's installed what looks to be 2 degree shims in the front leaf packs, doesn't seem like I would need those with only a 2.5" lift???
Should be fine, I like to see 6-7 but I prefer a heavy return to center, thick side should be to rear to increase caster
Thick part to the rear points pinion down lower and increases positive caster. Shims only need to be between the spring and the axle none on too the spring.I'm being dense, it seems to me the thick part to the rear turns the axle the wrong way to increase castor.
And don't shims on teh front axle need shims as a set, one above and one below the spring pack?
You want to rotate the top of the spindle back. Weight of the truck loads the wheels straight.
I've only ever done 2 degree shims, and never put them on top as well. Anything more got the spindles cut and turned.
Nope the ones on top are ok if they are there but do no need to be.
