Project "RESPAWN" - 1972 K5 Blazer
Cool stuff here!
Likely the most accurate name on the site. Well played
So, one of the PO's installed what looks to be 2 degree shims in the front leaf packs, doesn't seem like I would need those with only a 2.5" lift???
Measure the flat part of the steering knuckle and report back on your caster angle. Typically 4 to 6 works well
-G
It just can make a big difference in which direction they are installed!!!
They are pointing the pinion down (thick side toward the back). I haven't had a chance to get out there and measure the angle yet.
FYI, I didn't have or need shims on my Dana44 with 4" lift. Still don't need them. Unless you got some weird axle issue, you probably won't need them.
Looks like it's just under 5 degrees.
Should be fine, I like to see 6-7 but I prefer a heavy return to center, thick side should be to rear to increase caster
Aaaaand as luck would have it my new rebuilt steering box is leaking from the input shaft. Is it possible I simply overfilled the fluid a bit and the excess is leaking out? I fricking do not want to replace the steering box again!!!
I'm being dense, it seems to me the thick part to the rear turns the axle the wrong way to increase castor.
And don't shims on teh front axle need shims as a set, one above and one below the spring pack?
You want to rotate the top of the spindle back. Weight of the truck loads the wheels straight.
I've only ever done 2 degree shims, and never put them on top as well. Anything more got the spindles cut and turned.
Thick part to the rear points pinion down lower and increases positive caster. Shims only need to be between the spring and the axle none on too the spring.
OK, it got it now. I had to google some diagrams. lol.
This is what I was thinking of, I thought this was how the front axle was supposed to be done.
Positive caster is when the upper ball joint is leaned back if you are looking at it from the side and picturing a line drawn vertical through the upper and lower ball joints.
