- Joined
- Mar 3, 2000
- Posts
- 9,127
- Reaction score
- 7,092
400 Turbo trans, 203/205 doubler. Bought as a package.
Yep, the next time I'm near the Blazer I will check clearances to see if I can clock it up.
Was the 241 above the bottom of the crossmember in the first position?Kert's clocking ring has two options for clocking. I did mine in the first and can still run the 3" exhaust over it. The second position is flat and could be up into the floorpan and cross braces
If it is, it's just barely. I'll check tonightWas the 241 above the bottom of the crossmember in the first position?
