They have in my industry.
That is normal for a USS washer, the SAE washers are a better fit.I had to order 1/4" flat washers from Amazon. Everyone here has Hillman, and the supposed 1/4" washers fit a 5/16" perfectly. Not doing it, might as well not use a washer.
Haven't seen the Amazon ones I chose, be here in a day or so.
That's the difference between sae and uss washers. They fit one size bigger and have a larger od on sae. USS have a smaller od and fit the size they say. I may have mixed those up.I had to order 1/4" flat washers from Amazon. Everyone here has Hillman, and the supposed 1/4" washers fit a 5/16" perfectly. Not doing it, might as well not use a washer.
I use these guys for a lot. https://www.batterycablesusa.com/That is normal for a USS washer, the SAE washers are a better fit.
Wade, for those large cable ends check a welding shop or the welding section in the hardware store.
I also order a lot of that stuff from McMaster if I can't get it locally. Fast shipping and mostly quality USA made stuff.
I do the same, not color blind just don't like wiring.This is what you have to do when your brain is broken and you are partially color blind.
Everything gets a label.
I do that because I suffer from CRS.This is what you have to do when your brain is broken and you are partially color blind.
