ReTonkulous
Utlilmaster P30
Dialed the air screws and brought vacuum to 14in/Hg. Just needs a choke added from the old unit.
How many was that from the previous 15? Is it going to work? I have the ls version of your cam
And I feel it doesn’t create a lot of vacuum so the big block should be healthy
It already sounds better into the secondaries. Old carb puked then slowly increased rpm. Super rich at idle. Engine blowing lean under throttle. I would call it snappy now. 13.2 to 14.5 AFR all of the way through.
Doesn’t sound terrible but room to work
Flooring and seats are done. Now I am going to have to put the new column and shifter in. It is like driving with ape hangers.
Tank comes out tomorrow to see what the pickup issue is and fix the sending unit.
Drove it finally. Runs a lot better. Help me tune it. Never done it with an AFR gage.
Warmed up idle is at 13.2 to 13.5. 800rpm out of gear
Under normal acceleration, primaries only, and at speed under light load, 15.1to 15.4. Lean.
Under massed peddle, 10.5. Rich. No bogg.
So I am thinking, step up primary jets one step. No, I do not know what is in it. Run it to test.
Just came to mind. I could pull the cover and the air cleaner and watch what the secondaries are doing.
I would sort out the primaries first. You either need one step softer on the power enrichment Spring, or one more jet maybe two more jets in the front. After that I would mess with the secondaries, I would probably either go one rod size bigger, or three hanger size is deeper.
Mini me. He was able street legal it here.
View attachment 429015View attachment 429016
That little Honda- When you said street legal, any idea what hoops he had to jump through? This would be awesome for bumming around the coast. :cool:
And zombie comment #2, I always kept an HEI module in my glovebox after I had one crap out in my first K5 back in the 80s. :zombie3:
No hoops in Tennessee. Proof of import was needed. They street legal quads here. They are restricted to 50mph and under roads.
I think there are 3 and a complete distributor in my burb at any given time
I have a complete, new, distributor in the tool box.
Crazy how different states are on things like this. In NC golf carts are ok for streets under 30 MPH, but side by sides are not. I’ll have to check on these. Thanks :thumb:
I carry a complete distributor as well, figure that’s easier to stab in on the trail that tearing the old one apart and rebuilding it while everyone waits
Pulled the gas tank. Found the fuel gauge float hung up on the pick tube. My mistake when I installed it. I thought it cleared. So I turned the sending unit 90*. I did not measure the pickup when I put the new screen on it. Was obviously not for this tank. Was 3 inches short of the bottom. Now it is 1/2" off of the bottom. 3" off of the bottom, in a 40 gallon tank, is a bunch of gas. I hope this solves the running out when I know I have gas in it issue.
That is a lot of unusable fuel!
